Ana içeriğe geç
Insignia NS-SPBTBRICK-CM Speaker Replacement
Neye ihtiyacın var
  1. Insignia NS-SPBTBRICK-CM Speaker Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
  2. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 2, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 2, 2 resimden 2.
    • Turn the device around and gently push the speaker through until it separates from the sleeve.
  3. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 3, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
  4. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 4, 3 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 4, 3 resimden 2. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 4, 3 resimden 3.
    • Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
  5. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 5, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
  6. Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: adım 6, 3 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: adım 6, 3 resimden 2. Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: adım 6, 3 resimden 3.
    • Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device.
  7. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 7, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 7, 2 resimden 2.
    • Lift the front plastic shielding from the device.
  8. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the eight 10mm screws on the revealed front panel.
  9. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 9, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 9, 2 resimden 2.
    • Turn the device around and remove the rear panel from the device to reveal the device’s speaker units.
  10. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 10, 3 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 10, 3 resimden 2. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 10, 3 resimden 3.
    Satın Al
    • Remove the speaker brackets of the speaker to be replaced by unscrewing the three 7.5mm screws holding them in place with the Phillips #1 screwdriver.
    • If the brackets do not come out with the screws you may need to pull them out with tweezers.
  11. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 11, 2 resimden 1. Insignia NS-SPBTBRICK-CM Speaker Replacement: adım 11, 2 resimden 2.
    • Using tweezers, detach the cord connecting the speaker to the device and lift out the speaker.
Sonuç
If desired, repeat steps 10 and 11 to replace the other speaker within the device. Follow the steps of this guide and the battery replacement guide in reverse order to reassemble the device.
Bir başkası bu kılavuzu tamamladı.
ETHAN BRUNHOFER
158 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Harley Spring 2018 IUPUI, Team S2-G6, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S2G6
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 407
