Ana içeriğe geç
Insignia NS-VCS14SL7 Power Button Replacement
Neye ihtiyacın var
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: adım 1, 2 resimden 2.
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: adım 2, 3 resimden 1. Insignia NS-VCS14SL7 Power Button Replacement: adım 2, 3 resimden 2. Insignia NS-VCS14SL7 Power Button Replacement: adım 2, 3 resimden 3.
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: adım 3, 2 resimden 1. Insignia NS-VCS14SL7 Power Button Replacement: adım 3, 2 resimden 2.
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: adım 4, 1 resimden 1.
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: adım 5, 1 resimden 1.
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: adım 6, 2 resimden 1. Insignia NS-VCS14SL7 Power Button Replacement: adım 6, 2 resimden 2.
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: adım 7, 2 resimden 1. Insignia NS-VCS14SL7 Power Button Replacement: adım 7, 2 resimden 2.
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
Sonuç
Thibaut Pillot
434 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G3, Boczar Spring 2018 USF Tampa, Team S16-G3, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 211
