Ana içeriğe geç
Insignia NS-VCS14SL7 Stick Vacuum Power Button Replacement
Neye ihtiyacın var
  1. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: adım 1, 3 resimden 1. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: adım 1, 3 resimden 2. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: adım 1, 3 resimden 3.
    • Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
    • Pull up on the back cover of the vacuum handle and remove it.
  2. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: adım 2, 3 resimden 1. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: adım 2, 3 resimden 2. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: adım 2, 3 resimden 3.
    • Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
    • If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
Sonuç
Thibaut Pillot
434 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G3, Boczar Spring 2018 USF Tampa, Team S16-G3, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 169
