Ana içeriğe geç
Insignia NSD9PDVD15 Screen Replacement
Neye ihtiyacın var
  1. Insignia NSD9PDVD15 Screen Replacement, Screen: adım 1, 2 resimden 1. Insignia NSD9PDVD15 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Slide the “Open” tab on the top of the device.
    • This will allow you to open the device.
  2. Insignia NSD9PDVD15 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the six Phillips #00 screws from the screen casing.
    • To access two of the screws, first remove 2 small, flat rubber circles from the corners of the screen casing. Use a spudger if necessary.
  3. Insignia NSD9PDVD15 Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two screws from the hinge that holds together the screen casing and the disk panel.
    • Abruptly opening the device too wide will break the hinge. To fully access the hinge screws, firmly but gently open the device wider.
  4. Insignia NSD9PDVD15 Screen Replacement: adım 4, 1 resimden 1.
    • Insert the plastic opening tool into the rectangular holes and pry open in order to access the interior of the screen casing.
    • Remove the four screws and corresponding washers from the edges of the screen.
    • Use a plastic opening tool to prop open if necessary.
  5. Insignia NSD9PDVD15 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the eight screws from the green motherboard.
  6. Insignia NSD9PDVD15 Screen Replacement: adım 6, 1 resimden 1.
    • Unplug the red wires from the motherboard by gently pulling them off.
    • Then remove the screen.
  7. Insignia NSD9PDVD15 Screen Replacement: adım 7, 1 resimden 1.
    • Set the new screen in place.
Sonuç
Jen Rodas
1 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 2-5, Garvin Fall 2015 Ohio State, Team 2-5, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S2G5
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 465
