Ana içeriğe geç
Insignia Sport NS-4V17 Battery Replacement
Neye ihtiyacın var
  1. Insignia Sport NS-4V17 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Battery Replacement: adım 2, 2 resimden 1. Insignia Sport NS-4V17 Battery Replacement: adım 2, 2 resimden 2.
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Battery Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Battery Replacement: adım 4, 1 resimden 1.
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Poltorak
4 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G36
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,085
