Ana içeriğe geç
Insignia Sport NS-4V17 Motherboard Replacement
Neye ihtiyacın var
  1. Insignia Sport NS-4V17 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Motherboard Replacement: adım 2, 2 resimden 1. Insignia Sport NS-4V17 Motherboard Replacement: adım 2, 2 resimden 2.
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Motherboard Replacement: adım 4, 1 resimden 1.
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: adım 5, 2 resimden 1. Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: adım 5, 2 resimden 2.
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Motherboard Replacement: adım 7, 3 resimden 1. Insignia Sport NS-4V17 Motherboard Replacement: adım 7, 3 resimden 2. Insignia Sport NS-4V17 Motherboard Replacement: adım 7, 3 resimden 3.
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Motherboard Replacement: adım 8, 1 resimden 1.
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the white plastic ring from around the scroll wheel with your fingers.
  10. Insignia Sport NS-4V17 Motherboard Replacement: adım 10, 1 resimden 1.
    • Hold the sides of the device firmly with one hand.
    • Push down on the black favorite switch with your other hand so that it is pushed into the case.
  11. Insignia Sport NS-4V17 Motherboard Replacement: adım 11, 2 resimden 1. Insignia Sport NS-4V17 Motherboard Replacement: adım 11, 2 resimden 2.
    • With the component pushed in, lift up the top of the motherboard from the case.
    • Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wesley Ballar
88 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G36
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 468
