Ana içeriğe geç
Insignia Sport NS-4V17 Play/Pause Button Replacement
Neye ihtiyacın var
  1. Insignia Sport NS-4V17 Play/Pause Button Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 2, 2 resimden 1. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 2, 2 resimden 2.
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 4, 1 resimden 1.
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Play/Pause Button Replacement, Front Case Cover: adım 5, 2 resimden 1. Insignia Sport NS-4V17 Play/Pause Button Replacement, Front Case Cover: adım 5, 2 resimden 2.
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 6, 1 resimden 1.
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 7, 3 resimden 1. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 7, 3 resimden 2. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 7, 3 resimden 3.
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 8, 1 resimden 1.
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Play/Pause Button Replacement, Scroll Wheel: adım 9, 1 resimden 1.
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  10. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 10, 3 resimden 1. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 10, 3 resimden 2. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 10, 3 resimden 3.
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
  11. Insignia Sport NS-4V17 Play/Pause Button Replacement, Play/Pause Button: adım 11, 1 resimden 1.
    • Slightly insert plastic opening tool underneath any side of the play button.
  12. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 12, 2 resimden 1. Insignia Sport NS-4V17 Play/Pause Button Replacement: adım 12, 2 resimden 2.
    • Lift up slowly with the plastic opening tool and the play button should pop off.
Sonuç
Wesley Ballar
88 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G36
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 301
