Ana içeriğe geç
Inspiron 7359 2-in-1 Fan Replacement
Neye ihtiyacın var
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: adım 1, 1 resimden 1.
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: adım 2, 2 resimden 1. Inspiron 7359 2-in-1 Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: adım 3, 1 resimden 1.
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: adım 4, 1 resimden 1.
    • All hardware components should be exposed.
  5. Dikkatli ol: adımlar 5-6 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: adım 5, 1 resimden 1.
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: adım 6, 2 resimden 1. Inspiron 7359 2-in-1 Fan Replacement: adım 6, 2 resimden 2.
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: adım 7, 2 resimden 1. Inspiron 7359 2-in-1 Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: adım 8, 1 resimden 1.
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: adım 9, 1 resimden 1.
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Sonuç
Dominique
251 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 418
