Ana içeriğe geç
Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300)
Neye ihtiyacın var
  1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Back Cover: adım 1, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Back Cover: adım 1, 2 resimden 2.
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 2, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 2, 2 resimden 2.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 3, 1 resimden 1.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
    I have the UK model and I found Fascinating Captain’s method for removing the back cover to be simplicity itself:
    https://www.youtube.com/watch?v=JcZ711cx...
    Rob Butler - Yanıt
  4. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 4, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 4, 2 resimden 2.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Locate and Remove Write Protect Screw: adım 5, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Locate and Remove Write Protect Screw: adım 5, 2 resimden 2.
    • The write-protect screw is on the main logic board, just above the center (with the hinge at the top). It is to the right of the yellow-taped cables, to the left of the heatsink, and has copper-colored tape around its base.
    • Remove the 3.6mm screw with a Phillips #1 screwdriver.
    • Using tweezers, gently poke at the copper-colored tape around the base of the write-protect screw. Once enough is peeled up to get a grip, gently pull the sticker up and out.
    The inside of my Toshiba Chromebook 2 looks quite different, (maybe a European model?)
    However, in case anyone else has the same problem, this video helped me do this bit :
    https://youtu.be/JcZ711cxKdA
    alex.huzzey - Yanıt
  6. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Replace Cover: adım 6, 1 resimden 1.
    • Replace the cover on your Chromebook 2, working backwards from Step 4 to Step 1.
  7. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Back Up Any Important Files or Bookmarks: adım 7, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Back Up Any Important Files or Bookmarks: adım 7, 2 resimden 2.
    • The next step will wipe the Chromebook. If you have any files in your Downloads folder that you might want to hold onto, now is the time to upload them to Google Drive, or offload them onto a USB stick.
    • If you haven't enabled bookmark syncing in your Google account, you can back up your toolbar bookmarks by heading to the Bookmark Manager (Ctrl+Shift+O, or from the browser's three-dot menu, or right-clicking on the bookmark toolbar). Once in the bookmark manager, click that three-dot button in the upper-right, then choose Export Bookmarks.
  8. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Make a CloudReady USB Installer: adım 8, 1 resimden 1.
    • Head to CloudReady's page for the Home Edition and follow the instructions to turn a USB drive (8 GB or more) into a CloudReady installer.
    • It's easiest to make the USB installer on a Windows device, but you can also use a Mac, or this pre-wiped Chromebook, to make the installer.
    • If something goes wrong trying to use one USB drive, try another. They're more finicky than you'd expect for being "universal."
  9. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Enter Developer Mode: adım 9, 3 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Enter Developer Mode: adım 9, 3 resimden 2. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Enter Developer Mode: adım 9, 3 resimden 3.
    • We need to enable Developer Mode to install another BIOS and operating system. To enable Developer Mode, we must first invoke Recovery Mode.
    • To start Recovery Mode, hold down the Esc (top-left-most key) and Refresh keys (three keys to the right of Esc on this model), then press the Power button (top-right-most key) for a moment, until the unit turns on.
    • Once you see the exclamation mark and the message "Chrome OS is missing or damaged," press Control+D
    • You'll see one last check that you really want this (you do!): "To turn OS verification off, press Enter." Press Enter. As it says, your laptop will reboot, and your data will be wiped.
  10. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 10, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 10, 2 resimden 2.
    • When your Chromebook reboots, you'll get yet another warning screen: "OS verification is off." Press Ctrl+D one more time to get past this warning.
    • When you land inside Chrome OS, it will be as if you're setting it up for the first time. You can often choose a Wi-Fi network from the lower-right menu area. You might have to click a "Let's go" button to get to the screen where you can choose a Wi-Fi network. Select your Wi-Fi, but don't continue on!
    • Once you've selected a Wi-Fi network and successfully connected, hold the Ctrl and Alt keys and press the -> button (the second button from the esc key). You should see a stark-looking terminal screen and text prompt.
    • At the stark-looking prompt with a "localhost login," enter "chronos" as your login. That should change the prompt to "chronos@localhost," give you the permissions you need to run the next step.
    • If you're having trouble logging in at the localhost prompt, you can get back to the ChromeOS setup (Ctrl and Alt and <- button). Once you're inside ChromeOS, hold Ctrl and Alt and hit 'T', then type "shell" at the command prompt. This also makes it easier to copy/paste the command in the next step.
  11. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Run the Mr. Chromebox Script: adım 11, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300), Run the Mr. Chromebox Script: adım 11, 2 resimden 2.
    • Mr. Chromebox is a generous developer. Go to the page for his Chrome OS firmware script and type out the command on that page (starting with cd; curl ...
    • Choose "Install/Update Full ROM Firmware" from the menu by entering "3" and hitting Enter. You'll be prompted to agree to the inherent risk of what you're doing a few times by pressing "Y" for yes.
    • You'll also be prompted to create a backup copy of your stock firmware. You should answer "Y" to this, and grab another USB storage device, if you have one. Once you've backed it up onto a USB drive, back it up somewhere online, too!
    • Once you've finished installing the new firmware, enter "P" to power off.
    The menu option number to select the Full ROM firmware may be different. With the latest version it appears to be #2 instead of #3
    Daniel Howe - Yanıt
  12. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 12, 1 resimden 1.
    • With the Chromebook powered off, insert the CloudReady installer USB stick you made in step 6 (or go make it now on another computer if you haven't done so).
    • With the USB stick in one of the USB ports, power on the Chromebook. You should see a new thing; a speedy rabbit at the top of your boot screen, and a message at bottom, "Press ESC for Boot Options/Settings."
    • Do it! Press Escape before the bunny disappears. You'll be given a simple prompt to choose a device. Choose the option that looks like the USB stick you've inserted. It might show the name of the maker, like "Lexar" or "Sandisk" or just "Generic USB."
    • If you miss it, just wait a moment; you should end up inside the BIOS options anyways, because there's no operating system installed. Choose the "Boot device" menu (or something similar) and look for where you can choose your USB stick for booting.
  13. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 13, 2 resimden 1. Install CloudReady (or other OS) on Toshiba Chromebook 2 (CB35-C3300): adım 13, 2 resimden 2.
    • You'll get a CloudReady setup prompt that looks quite similar to the traditional Chromebook setup. Hooray!
    • But! You don't want to go through this setup—it's just for setting up a "live" session. To actually install CloudReady, click the icons in the lower-right corner, and choose Install CloudReady.
    • Follow CloudReady's installation instructions from here.
Sonuç
Now you’re running CloudReady and getting regular security and Chrome updates. You can use also use this guide to install any other OS (Windows, Linux) from a USB stick.
12 farklı kişi bu kılavuzu tamamladı.
Kevin Purdy
4.054 İtibar
5 adet Kılavuz yazıldı
13 Yorum
okay i have done everything but for some reason when i go to log in the chrome system does not take my original login and password anymore. I have not changed anything but it does not accept the password. Is there a reason?
amina2306 - Yanıt
This worked! Thank you so much for these instructions.
The only thing which wasn't clear was that the inside of my Toshiba Chromebook 2 looks quite different, (maybe a European model?) so wasn't clear how to find the write protect screw. However, in case anyone else has the same problem, this video helped me do that bit :
alex.huzzey - Yanıt
Excellent instructions, thank you so much, this worked for me. I used these instructions combined with Fascinating Captain’s video at https://www.youtube.com/watch?v=JcZ711cx... which was invaluable as I have the UK model and the write protect screw is in a slightly different place.
Rob Butler - Yanıt
I just completed this on my Toshiba Chromebook 2! Thank you for this fantastic guide!!!
David Huber - Yanıt
Hi Kevin. Thanks for the clear instructions. I’m preparing to do this and had a question: At stage 10 when you have logged in as local host, can you still visit the Mr Chromebox site on another tab to cut and paste the firmware script? With thanks.
John Higham - Yanıt
Worked for me! I’m glad to be getting some more life out of my first chromebook. BUT, the backlit keyboard is no longer working :( any suggestions?
Jason Lozano - Yanıt
Updated Toshiba Chromebook 2, no sound?
Rod Wanner - Yanıt
Yep no sounds.. the audio drivers are missing and can't be fixed
Mr Dylmax -
Works perfectly
However things to note:
Audio is broken
Mr Dylmax - Yanıt
How to track someone's location by phone number - detailed instructions.
Whether you're a concerned parent worrying about your kids' day-to-day whereabouts, or an employer who wants to track employee travel routes and schedules, or if you've just misplaced or misplaced your phone, being able to track your phone's location is essential. As a rule, special software is used for this, but it is very easy to detect and disable it. So what to do in this case? You can track the location without installing programs, you need to know - only the phone number, read more about how to do it -<a https://localizarcelularpornumero.com/
Find Car - Yanıt
Just noting that since Google has acquired CloudReady it's actually ChromeOS Flex that you'll install now. The setup steps are pretty much the same though. I'm in the process of installing ChromeOS Flex on this Chromebook now in the hopes to get some more life out of it.
Update: With the latest ChromeOS Flex it appears that the sound issue is resolved, for that matter the machine works like a 100% native ChromeOS experience.
Tim Nolte - Yanıt
hey, how can i fix the sound problem?? i just installed this OS and i dont know to fix the problem, i got chrome OS flex version : 119.0.6045.214
Jose Pablo González -
Do you know how to get the audio drivers for ChromeOS Flex? The driver website shows up with no drivers.
ps im on ver. 119.0.6045.214.
(https://support.dynabook.com/support/mod...)
flxurilly - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 95
Her zaman: 10,248
