Ana içeriğe geç
Install LED Pod Lights on a Off-Road Truck Jeep
Neye ihtiyacın var
  1. Install LED Pod Lights on a Off-Road Truck Jeep, LED Pod Light: adım 1, 2 resimden 1. Install LED Pod Lights on a Off-Road Truck Jeep, LED Pod Light: adım 1, 2 resimden 2.
    • First, tape over the area you want your new LED pod lights to sit and get the outer brackets and draw where you need to cut.
    FixBot'a Sor
    Yorum Ekle
  2. Install LED Pod Lights on a Off-Road Truck Jeep: adım 2, 3 resimden 1. Install LED Pod Lights on a Off-Road Truck Jeep: adım 2, 3 resimden 2. Install LED Pod Lights on a Off-Road Truck Jeep: adım 2, 3 resimden 3.
    • Now cut out the hole with an angle grinder.
    • Then, take a drill and cut the holes for the LED pod lights to screw on.
    FixBot'a Sor
    Yorum Ekle
  3. Install LED Pod Lights on a Off-Road Truck Jeep: adım 3, 3 resimden 1. Install LED Pod Lights on a Off-Road Truck Jeep: adım 3, 3 resimden 2. Install LED Pod Lights on a Off-Road Truck Jeep: adım 3, 3 resimden 3.
    • Insert in your new LED Pod Lights and screw it in tightly to your truck.
    FixBot'a Sor
    Yorum Ekle
    • For wiring, it depends on what you want the functionality to be.
    • For example, for reverse lights, tap the wires to existing reverse lamp positive and negative.
    FixBot'a Sor
    Yorum Ekle
Sonuç
This LED pod light kit for truck installation is straight forward and will transform your vehicle into a one of a kind machine. Not only is it super bright but also looks great!
Eric Wu
3.600 İtibar
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 107
Her zaman: 4,371
