Ana içeriğe geç
Install the Battery on bObi Pet
Neye ihtiyacın var
  1. Install the Battery on bObi Pet, Turn bObi Pet Off: adım 1, 2 resimden 1. Install the Battery on bObi Pet, Turn bObi Pet Off: adım 1, 2 resimden 2.
    • Make sure bObi Pet's power switch is turned OFF.
    • Then, flip bObi Pet over onto a flat surface, so the wheels point up.
  2. Install the Battery on bObi Pet, Open the Battery Compartment: adım 2, 3 resimden 1. Install the Battery on bObi Pet, Open the Battery Compartment: adım 2, 3 resimden 2. Install the Battery on bObi Pet, Open the Battery Compartment: adım 2, 3 resimden 3.
    • Remove the two screws holding her battery cover in place.
    • Remove the battery cover. Keep the cover and screws close by for the next step.
  3. Install the Battery on bObi Pet, Plug in the New Battery: adım 3, 3 resimden 1. Install the Battery on bObi Pet, Plug in the New Battery: adım 3, 3 resimden 2. Install the Battery on bObi Pet, Plug in the New Battery: adım 3, 3 resimden 3.
    • Plug the new battery in at the circuit junction.
    • Tuck the wire into the side of the compartment.
    • Ensure the wires are not in the way, then, slide the battery straight down.
  4. Install the Battery on bObi Pet, Replace the Battery Cover: adım 4, 3 resimden 1. Install the Battery on bObi Pet, Replace the Battery Cover: adım 4, 3 resimden 2. Install the Battery on bObi Pet, Replace the Battery Cover: adım 4, 3 resimden 3.
    • Replace the battery cover so that it lies flat.
    • Reinstall the 2 screws to finish the installation process.
Sonuç
After finishing the battery installation correctly, turn bObi Pet's side power switch to ON and your robotic vacuum should be ready to work.
Chelsea
2.278 İtibar
31 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 166
