Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
Lift the memory cover up and out of the computer.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 3 screws from the rear wall of the battery compartment:
One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
Remove the following 4 screws from the back of the computer:
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Remove the two Phillips screws from the optical drive (right) side of the computer:
Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Bu adımda kullanılan alet:Plastic Cards$2.99-
Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
Remove the two Phillips screws from the side of the optical drive.
Two 3.25 mm Phillips #000 (head: 4 mm. dia. x .3 mm thick)
Disconnect the orange optical drive ribbon cable connector from the logic board by prying it straight up using either a finger or a spudger.
Disconnect the newly revealed display data cable's plug from the logic board by pulling it upward using its black pull-tab.
Disconnect the newly-revealed hard drive cable's plug from the logic board by pulling it upward using its black tab.
Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
During reassembly, be sure to route the cables beneath the tape before reattaching it.
Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
Remove the 2 mm Phillips #00 screw securing the rear corner of the optical drive.
The silver-jacketed Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to remove the screw holding the ground shield lugs for the two nearby cables before you can move the Bluetooth cable aside sufficiently. This screw is 7mm in earlier models, and may be 4.2mm in Santa Rosa/Penryn and 2009 models.
Lift the Bluetooth antenna board from the front edge of the optical drive.
Deroute the hard drive cable from under the clips along the near side of the optical drive.
Lift the side of the optical drive closest to you, then slide the drive towards you, and up and out of the computer.
First, slide its side nearest to the rear of the Macbook under the edge of the rear frame to the left of the hinge, while also sliding the optical drive's mounting tab at its upper left corner under the cables at this location.
Lower the drive partially into the lower housing. Keep the hard drive cable away from the optical drive bay.
Before dropping the drive fully in place, use a spudger to push forward (towards the front of the drive) on the screw hole in the drive's mounting tab.
Push forward the slider, which runs along the far side of the drive, to insert the end of this slider into a small channel in the lower case's frame. This helps hold the drive in place.
Peel up the black tape partially covering the orange optical drive cable.
Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
Peel up the L-shaped piece of black tape from the top of the drive.
Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
69 farklı kişi bu kılavuzu tamamladı.
7 Yorum
I just successful follow this guide to add 2nd hard drive to my old Macbook White 4.1. It really helpful, just a part take me some time. It is bluetooth atena board part, it cause my keyboard got big gap. Finally I hide it below my Optibay, so far the bluetooth still working well. Thanks iFix. :D
only took about 10-15 minutes for me when i was practicing on my broken Macbook white(as not to risk my new one), this guide is the best one i've seen yet, it is a little bit harder than moderate when you don't have a small phillips screwdriver though, but my steak knife worked pretty well too, thanks guys
Thanks, I used this guide to reuse the hard drive as an external.
J'installe ssd PNY dans la boîtier, mais mbp ne reconnaît pas ce ssd. Merci pour m'aider à fixit.
