Ana içeriğe geç
Installing Mercedes W166 RAV Tool Box
Neye ihtiyacın var
  1. Installing Mercedes W166 RAV Tool Box, RAV Tool Box: adım 1, 2 resimden 1. Installing Mercedes W166 RAV Tool Box, RAV Tool Box: adım 1, 2 resimden 2.
    • 1. Vehicle Preparation
    • Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
    • Remove rear seats as in WIS instructions (Save seat mounting hardware)
  2. Installing Mercedes W166 RAV Tool Box: adım 2, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 2, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 2, 3 resimden 3.
    • Remove bolt from rear deck sill plate
    • Unclip rear deck sill plate and remove.
  3. Installing Mercedes W166 RAV Tool Box: adım 3, 1 resimden 1.
    • Remove plastic covers
    • Remove Felt liner
  4. Installing Mercedes W166 RAV Tool Box: adım 4, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 4, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 4, 3 resimden 3.
    • Remove side consoles and center support (T30 10 Bolts)
  5. Installing Mercedes W166 RAV Tool Box: adım 5, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 5, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 5, 3 resimden 3.
    • Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
    • Pay attention to the pin to align properly
    • NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
  6. Installing Mercedes W166 RAV Tool Box: adım 6, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 6, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 6, 3 resimden 3.
    • 2. Installation of Front Box
    • Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
    • Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers). Pay attention not to break off the alignment pin, which will be inside the post after mounting.
    • DO NOT mount the box to the center bracket at this point
  7. Installing Mercedes W166 RAV Tool Box: adım 7, 2 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 7, 2 resimden 2.
    • 3. Installation of the rear plate
    • Install 6 rear support brackets and tighten finger tight
  8. Installing Mercedes W166 RAV Tool Box: adım 8, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 8, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 8, 3 resimden 3.
    • Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
    • Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
  9. Installing Mercedes W166 RAV Tool Box: adım 9, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 9, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 9, 3 resimden 3.
    • Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
  10. Installing Mercedes W166 RAV Tool Box: adım 10, 2 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 10, 2 resimden 2.
    • Install 3 bolts securing base plate to vehicle frame
    • and 4th bolt securing the tool box rail to the base plate and vehicle frame.
    • Put bolt sizes in
  11. Installing Mercedes W166 RAV Tool Box: adım 11, 2 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 11, 2 resimden 2.
    • Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
  12. Installing Mercedes W166 RAV Tool Box: adım 12, 2 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 12, 2 resimden 2.
    • Fully tighten M8 (20 Nm)
    • Fully tighten M6 (8 Nm)
  13. Installing Mercedes W166 RAV Tool Box: adım 13, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 13, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 13, 3 resimden 3.
    • Fully tighten M10 bolts (35 Nm)
  14. Installing Mercedes W166 RAV Tool Box: adım 14, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 14, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 14, 3 resimden 3.
    • 4. Install box
    • Remove drawers and slide box on rail guides, align with bolt holes
    • Install 6 (M12) bolts and fully tighten to 66 Nm
  15. Installing Mercedes W166 RAV Tool Box: adım 15, 3 resimden 1. Installing Mercedes W166 RAV Tool Box: adım 15, 3 resimden 2. Installing Mercedes W166 RAV Tool Box: adım 15, 3 resimden 3.
    • Install drawers.
    • After drawer is installed move rail clip to locked position
  16. Installing Mercedes W166 RAV Tool Box: adım 16, 1 resimden 1.
    • Fasten seat belt with bolt to floor
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Stefan
275 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 3,893
