Ana içeriğe geç
Installing a Petsafe Removable Dog Panel
Neye ihtiyacın var
  1. Installing a Petsafe Removable Dog Panel, Petsafe Dog Panel: adım 1, 1 resimden 1.
    • Make sure you have all the tools necessary.
  2. Installing a Petsafe Removable Dog Panel: adım 2, 1 resimden 1.
    • Receive your PetSafe dog door in the mail.
  3. Installing a Petsafe Removable Dog Panel: adım 3, 2 resimden 1. Installing a Petsafe Removable Dog Panel: adım 3, 2 resimden 2.
    • Measure the height of the sliding glass door frame.
  4. Installing a Petsafe Removable Dog Panel: adım 4, 3 resimden 1. Installing a Petsafe Removable Dog Panel: adım 4, 3 resimden 2. Installing a Petsafe Removable Dog Panel: adım 4, 3 resimden 3.
    • Remove your lock latch from the sliding door frame.
    • Lock latches may vary
  5. Installing a Petsafe Removable Dog Panel: adım 5, 2 resimden 1. Installing a Petsafe Removable Dog Panel: adım 5, 2 resimden 2.
    • Slide the top of your dog panel into the top track of the sliding glass door.
    • Place the bottom portion of the dog panel into the bottom track of the sliding glass door.
  6. Installing a Petsafe Removable Dog Panel: adım 6, 2 resimden 1. Installing a Petsafe Removable Dog Panel: adım 6, 2 resimden 2.
    • Measure 12” from the top, down the side of your sliding glass door frame and mark it.
    • Mark 1” above the pet flap onto the edge of your sliding glass door.
  7. Installing a Petsafe Removable Dog Panel: adım 7, 3 resimden 1. Installing a Petsafe Removable Dog Panel: adım 7, 3 resimden 2. Installing a Petsafe Removable Dog Panel: adım 7, 3 resimden 3.
    • With a 9/64ths drill bit, drill clearance holes into the marks made on the sliding glass door frame
    • DO NOT GO THROUGH THE DOG PANEL
  8. Installing a Petsafe Removable Dog Panel: adım 8, 3 resimden 1. Installing a Petsafe Removable Dog Panel: adım 8, 3 resimden 2. Installing a Petsafe Removable Dog Panel: adım 8, 3 resimden 3.
    • Fasten the panel to the interior side of the sliding glass frame with the provided ⅝” screws.
    • MAKE SURE YOU ARE DRILLING OUTSIDE OF THE RIBBED LINE ON THE DOG PANEL.
    • DO NOT OVERTIGHTEN.
  9. Installing a Petsafe Removable Dog Panel: adım 9, 2 resimden 1. Installing a Petsafe Removable Dog Panel: adım 9, 2 resimden 2.
    • Tighten the screws with a screwdriver.
  10. Installing a Petsafe Removable Dog Panel: adım 10, 3 resimden 1. Installing a Petsafe Removable Dog Panel: adım 10, 3 resimden 2. Installing a Petsafe Removable Dog Panel: adım 10, 3 resimden 3.
    • Repeat steps 8 and 9 to secure the dog panel into place. Follow these steps when drilling into the clearance hole marked at the top of the frame.
  11. Installing a Petsafe Removable Dog Panel: adım 11, 1 resimden 1.
    • Slide your sliding door flush against the dog door.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Novello
196 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S1-G1, Bender Fall 2018 UC Davis, Team S1-G1, Bender Fall 2018 üyesi
UCD-BENDER-F18S1G1
3 Üyeler
1 Kılavuz yazıldı
2Kılavuz Yorumları
My dog won’t push hard enough for the magnet to open. Is there a way to temporarily remove the magnet on either the frame or the flap?
LisaD - Yanıt
LisaD put a piece of masking tape over the magnet or a couple of layers of tape to make it easier to open maybe?
Robert Merry -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 1,590
