Ana içeriğe geç
Giriş
This guide will walk you through the steps necessary to patch the elbow of your Patagonia sweater. A piece of felted sweater or corduroy fabric will make a great patch for your sweater. Choose a patch color that compliments the color of your sweater. You can sew the patch on by hand if you don’t have a sewing machine. Whether you hand-sew or machine-sew, you will need a ballpoint needle to prevent any snagging while sewing. If you choose to sew by hand, simply ignore the steps involving the sewing machine. Whichever method you choose, be sure to only sew through the top layer of the sleeve, or else you’ll sew your sleeve shut! New to sewing? Check out our sewing glossary.
  1. Lay your sweater flat on a work surface, damage side up. Measure the length of the hole. Measure the width of the hole.
    • Lay your sweater flat on a work surface, damage side up.
    • Measure the length of the hole.
    • Measure the width of the hole.
  2. On a piece of paper, mark the endpoints of a line that measures the length of the hole, plus one inch. Mark the center of the two endpoints. From the center, turn the measuring tape 90 degrees. Mark the endpoints of a line that measures the width of the hole, plus one inch.
    • On a piece of paper, mark the endpoints of a line that measures the length of the hole, plus one inch.
    • Mark the center of the two endpoints.
    • From the center, turn the measuring tape 90 degrees. Mark the endpoints of a line that measures the width of the hole, plus one inch.
  3. Sketch a curve connecting the endpoints of the length and width. Draw a straight line connecting the endpoints of the width, going though the center point. Fold the paper in half on the straight line.
    • Sketch a curve connecting the endpoints of the length and width.
    • Draw a straight line connecting the endpoints of the width, going though the center point.
    • Fold the paper in half on the straight line.
    • Cut along the curved line. The piece you have just cut out will be your pattern.
  4. Lay your pattern over the hole to verify that it is the correct size and shape. Lay your pattern over the hole to verify that it is the correct size and shape.
    • Lay your pattern over the hole to verify that it is the correct size and shape.
  5. Lay your pattern over the piece of fabric you’ve choosen to use as a patch. It is important to choose a fabric that is only slightly heavier than your sweater, such as corduroy or a felted sweater. Anything heavier, such as denim or leather, may cause the sweater to tear. To felt a sweater, simply put a 100% wool sweater through the washer and dryer. When it comes out, the sweater should be shrunken and have a very tight weave.
    • Lay your pattern over the piece of fabric you’ve choosen to use as a patch.
    • It is important to choose a fabric that is only slightly heavier than your sweater, such as corduroy or a felted sweater. Anything heavier, such as denim or leather, may cause the sweater to tear.
    • To felt a sweater, simply put a 100% wool sweater through the washer and dryer. When it comes out, the sweater should be shrunken and have a very tight weave.
    • Pin your pattern piece onto your patch fabric.
    • If you double up the patch fabric before you pin you will get two identical patches, one for each side.
  6. Using fabric scissors, cut around the pattern piece. Inspect the patch, going back to clean up any rough edges with scissors.
    • Using fabric scissors, cut around the pattern piece.
    • Inspect the patch, going back to clean up any rough edges with scissors.
  7. Lay the patch over the hole, positioning it where you would like it to be. Lay the patch over the hole, positioning it where you would like it to be.
    • Lay the patch over the hole, positioning it where you would like it to be.
  8. Pin the patch into place. Only pin the patch to the top layer of the sleeve fabric; if you pin and sew them both, you will sew the sleeve shut.
    • Pin the patch into place.
    • Only pin the patch to the top layer of the sleeve fabric; if you pin and sew them both, you will sew the sleeve shut.
  9. Insert a ballpoint needle into your sewing machine. Each sewing machine is a little bit different, so check your user's manual if you aren't sure how to change your needle. Each sewing machine is a little bit different, so check your user's manual if you aren't sure how to change your needle.
    • Insert a ballpoint needle into your sewing machine.
    • Each sewing machine is a little bit different, so check your user's manual if you aren't sure how to change your needle.
  10. Slide the sleeve over the arm of your sewing machine, just like you’d put the sleeve over your own arm. You may need to remove the table from your sewing machine to allow the sweater sleeve to slide over the sewing machine arm. Check you sewing machine manual for specific instructions on your machine. You may need to remove the table from your sewing machine to allow the sweater sleeve to slide over the sewing machine arm. Check you sewing machine manual for specific instructions on your machine.
    • Slide the sleeve over the arm of your sewing machine, just like you’d put the sleeve over your own arm.
    • You may need to remove the table from your sewing machine to allow the sweater sleeve to slide over the sewing machine arm. Check you sewing machine manual for specific instructions on your machine.
  11. Align the very edge of the patch with the needle. Sew around the edge of the patch, turning the sleeve as you go. For a more stable patch, use zig-zag or satin stitch.
    • Align the very edge of the patch with the needle.
    • Sew around the edge of the patch, turning the sleeve as you go.
    • For a more stable patch, use zig-zag or satin stitch.
    • Sew until you come all the way around, retracing your first stitches.
  12. Slide the sleeve off the arm of your sewing machine. Clip any loose threads. Repeat on the other sleeve if you want symmetrical professor patches.
    • Slide the sleeve off the arm of your sewing machine.
    • Clip any loose threads.
    • Repeat on the other sleeve if you want symmetrical professor patches.
Sonuç
If you need further help, contact Patagonia Customer Service.
2 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
86.433 İtibar
132 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 39
Son 7 gün: 268
Son 30 gün: 1,004
Her zaman: 46,937
