Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
There are many benefits to adding a second hard drive to your iMac such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Neye ihtiyacın var
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
be sure to tuck the microphone cable and connector into the void next to the camera board.
Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
If necessary, de-route the LCD temperature sensor cable from behind the logic board.
With the display panel still lifted, disconnect the four inverter cables.
If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
If necessary, remove the piece of foam tape covering the optical drive thermal sensor.
To remove the optical drive thermal sensor, use the tip of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
63 farklı kişi bu kılavuzu tamamladı.
10 Yorum
my iMac2008early dvdrom is PATA!!!!!!
plz fix you page!!!
I'd sound a caution before replacing the optical drive with anything else if it's on PATA. It'll be slow... Better using an external enclosure and FW800.
I have an iMac early 2008. Do you recommended to replace the optical super drive super with an SSD?
Cool. It worked nicely. I replaced the superdrive with an SSD. As expected, due to the slow PATA connection, speed increase is not as dramatic as one would expect with a SATA.
