Ana içeriğe geç
Instant Pot IP-DUO80 V2 Float Valve Replacement
Neye ihtiyacın var
  1. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: adım 1, 3 resimden 1. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: adım 1, 3 resimden 2. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: adım 1, 3 resimden 3.
    • Remove the lid by twisting it counter-clockwise.
    FixBot'a Sor
  2. Instant Pot IP-DUO80 V2 Float Valve Replacement: adım 2, 1 resimden 1.
    • Place the lid upside down on a stable surface.
    FixBot'a Sor
  3. Instant Pot IP-DUO80 V2 Float Valve Replacement: adım 3, 3 resimden 1. Instant Pot IP-DUO80 V2 Float Valve Replacement: adım 3, 3 resimden 2. Instant Pot IP-DUO80 V2 Float Valve Replacement: adım 3, 3 resimden 3.
    • Remove the white rubber cover from the red float valve by pulling it off gently.
    • The red float valve will fall once the white cover is removed.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kayla Meacham
646 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G2
4 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
Harry Ethington - Yanıt Paylaş
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
ixbah aries - Yanıt Paylaş
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
Resist - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 101
Her zaman: 6,432
