Ana içeriğe geç
Instant Pot IP-DUO80 V2 LED Display Replacement
Neye ihtiyacın var
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: adım 1, 3 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: adım 1, 3 resimden 2. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: adım 1, 3 resimden 3.
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
    FixBot'a Sor
    Yorum Ekle
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 2, 3 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 2, 3 resimden 2. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 2, 3 resimden 3.
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
    FixBot'a Sor
    Yorum Ekle
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 3, 2 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 3, 2 resimden 2.
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
    FixBot'a Sor
    Yorum Ekle
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 4, 2 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 4, 2 resimden 2.
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
    FixBot'a Sor
    Yorum Ekle
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 5, 3 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 5, 3 resimden 2. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 5, 3 resimden 3.
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 6, 1 resimden 1.
    • Lift the silver outer shell off of the top black ring.
    FixBot'a Sor
    Yorum Ekle
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 7, 3 resimden 1. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 7, 3 resimden 2. Instant Pot IP-DUO80 V2 LED Display Replacement: adım 7, 3 resimden 3.
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kayla Meacham
646 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G2
4 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I get the replacement for the display?
Starfish Doodle - Yanıt Paylaş
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 102
Her zaman: 8,452
