Ana içeriğe geç
Instax Mini 90 Battery Contact Replacement
Neye ihtiyacın var
  1. Instax Mini 90 Battery Contact Replacement, Battery: adım 1, 2 resimden 1. Instax Mini 90 Battery Contact Replacement, Battery: adım 1, 2 resimden 2.
    • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
    FixBot'a Sor
    Yorum Ekle
  2. Instax Mini 90 Battery Contact Replacement: adım 2, 2 resimden 1. Instax Mini 90 Battery Contact Replacement: adım 2, 2 resimden 2.
    • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
    • Completely open the gate and remove from camera. Take out the battery and replace the gate.
    FixBot'a Sor
    Yorum Ekle
  3. Instax Mini 90 Battery Contact Replacement, Battery Contact: adım 3, 3 resimden 1. Instax Mini 90 Battery Contact Replacement, Battery Contact: adım 3, 3 resimden 2. Instax Mini 90 Battery Contact Replacement, Battery Contact: adım 3, 3 resimden 3.
    • Turn camera around to its backside.
    • Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Instax Mini 90 Battery Contact Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #000 Screwdriver to remove the five 3.5 mm screws located in the backside door of the camera.
    FixBot'a Sor
    Yorum Ekle
  5. Instax Mini 90 Battery Contact Replacement: adım 5, 3 resimden 1. Instax Mini 90 Battery Contact Replacement: adım 5, 3 resimden 2. Instax Mini 90 Battery Contact Replacement: adım 5, 3 resimden 3.
    • Remove the black plastic piece on top, then remove the thin, metal piece. This metal piece is the battery contact.
    • Replace the battery contact with the new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elliott Tegan-Tawney
690 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G1
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
John Doe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 5,511
