Ana içeriğe geç
Inter-tel IP 8660 Button Pad Replacement
Neye ihtiyacın var
  1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Button Pad Replacement: adım 2, 3 resimden 1. Inter-tel IP 8660 Button Pad Replacement: adım 2, 3 resimden 2. Inter-tel IP 8660 Button Pad Replacement: adım 2, 3 resimden 3.
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Button Pad Replacement: adım 3, 1 resimden 1.
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: adım 4, 1 resimden 1.
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Button Pad Replacement: adım 5, 1 resimden 1.
    • Lift up the speaker.
  6. Inter-tel IP 8660 Button Pad Replacement, Button Pad: adım 6, 1 resimden 1.
    • Lift up the motherboard and set aside
  7. Inter-tel IP 8660 Button Pad Replacement: adım 7, 1 resimden 1.
    • Peel off all rubber button covers.
  8. Inter-tel IP 8660 Button Pad Replacement: adım 8, 1 resimden 1.
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 785
