Ana içeriğe geç
Inter-tel IP 8660 Handset Back Cover Replacement
Neye ihtiyacın var
  1. Inter-tel IP 8660 Handset Back Cover Replacement, Handset Back Cover: adım 1, 1 resimden 1.
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Back Cover Replacement: adım 2, 2 resimden 1. Inter-tel IP 8660 Handset Back Cover Replacement: adım 2, 2 resimden 2.
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Back Cover Replacement: adım 3, 2 resimden 1. Inter-tel IP 8660 Handset Back Cover Replacement: adım 3, 2 resimden 2.
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
Sonuç
Ekip
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 665
