Ana içeriğe geç
Inter-tel IP 8660 Handset Microphone and Receiver. Replacement
Neye ihtiyacın var
  1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Back Cover: adım 1, 1 resimden 1.
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 2, 2 resimden 1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 2, 2 resimden 2.
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 3, 2 resimden 1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 3, 2 resimden 2.
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  4. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Microphone and Receiver.: adım 4, 1 resimden 1.
    • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  5. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 5, 3 resimden 1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 5, 3 resimden 2. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 5, 3 resimden 3.
    • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
    • Note: The screws come with washers.
  6. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 6, 2 resimden 1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: adım 6, 2 resimden 2.
    • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
    • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
Sonuç
Ekip
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 965
