Ana içeriğe geç
Inter-tel IP 8660 LCD Screen Replacement
Neye ihtiyacın var
  1. Inter-tel IP 8660 LCD Screen Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 LCD Screen Replacement: adım 2, 3 resimden 1. Inter-tel IP 8660 LCD Screen Replacement: adım 2, 3 resimden 2. Inter-tel IP 8660 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 LCD Screen Replacement, Internal speaker: adım 4, 1 resimden 1.
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Lift up the speaker.
  6. Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 1. Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 2. Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 3.
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 LCD Screen Replacement: adım 7, 3 resimden 1. Inter-tel IP 8660 LCD Screen Replacement: adım 7, 3 resimden 2. Inter-tel IP 8660 LCD Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 LCD Screen Replacement: adım 9, 2 resimden 1. Inter-tel IP 8660 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 LCD Screen Replacement: adım 10, 3 resimden 1. Inter-tel IP 8660 LCD Screen Replacement: adım 10, 3 resimden 2. Inter-tel IP 8660 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 847
