Ana içeriğe geç
Inter-tel IP 8660 Rear Cover Replacement
Neye ihtiyacın var
  1. Inter-tel IP 8660 Rear Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Rear Cover Replacement: adım 2, 3 resimden 1. Inter-tel IP 8660 Rear Cover Replacement: adım 2, 3 resimden 2. Inter-tel IP 8660 Rear Cover Replacement: adım 2, 3 resimden 3.
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Rear Cover Replacement: adım 3, 1 resimden 1.
    • Lift up the back cover and set it aside.
Sonuç
Mariano Bautista
16 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 543
