Giriş
This guide shows how to remove the interconnect cables in your Google Pixel 9 Pro.
Neye ihtiyacın var
Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
Insert the tip of an opening pick in the gap.
Slide your opening pick along the bottom edge to separate the adhesive securing it.
Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
Bu adımda kullanılan alet:FixMat$36.95
Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
Four 5.4 mm‑long screws
One 1.5 mm‑long screw
Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
One 2.3 mm‑long screw
One 5.4 mm‑long screw
Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
Use the flat end of a spudger to pry up and disconnect the press connector near the bottom left corner of the logic board.
Use the point of a spudger to disconnect the press connector just to the right of the previous one.
Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the charging board cover.
Use the point of a spudger to pry up and disconnect the three press connectors on the top edge of the charging board.
Use your fingers to remove the left interconnect cable.
Use a Torx Plus 3IP screwdriver to remove the two 2.5 mm‑long screws securing the bottom of the right interconnect cable.
