Ana içeriğe geç
Interlink VP4550 Case Replacement
Neye ihtiyacın var
  1. Interlink VP4550 Case Replacement, Case: adım 1, 3 resimden 1. Interlink VP4550 Case Replacement, Case: adım 1, 3 resimden 2. Interlink VP4550 Case Replacement, Case: adım 1, 3 resimden 3.
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Case Replacement: adım 2, 3 resimden 1. Interlink VP4550 Case Replacement: adım 2, 3 resimden 2. Interlink VP4550 Case Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Case Replacement: adım 3, 2 resimden 1. Interlink VP4550 Case Replacement: adım 3, 2 resimden 2.
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Case Replacement: adım 4, 2 resimden 1. Interlink VP4550 Case Replacement: adım 4, 2 resimden 2.
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
Sonuç
To reassemble your device, follow these instructions in reverse order. It's possible to either use a new case for your phone, or put the old one back on.
Bir başkası bu kılavuzu tamamladı.
Rachel
1 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Buehl Spring 2014 Ohio State, Team 1-1, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 309
