Ana içeriğe geç
Interlink VP4550 Circuit Board Replacement
Neye ihtiyacın var
  1. Interlink VP4550 Circuit Board Replacement, Case: adım 1, 3 resimden 1. Interlink VP4550 Circuit Board Replacement, Case: adım 1, 3 resimden 2. Interlink VP4550 Circuit Board Replacement, Case: adım 1, 3 resimden 3.
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Circuit Board Replacement: adım 2, 3 resimden 1. Interlink VP4550 Circuit Board Replacement: adım 2, 3 resimden 2. Interlink VP4550 Circuit Board Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Circuit Board Replacement: adım 3, 2 resimden 1. Interlink VP4550 Circuit Board Replacement: adım 3, 2 resimden 2.
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Circuit Board Replacement: adım 4, 2 resimden 1. Interlink VP4550 Circuit Board Replacement: adım 4, 2 resimden 2.
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  5. Interlink VP4550 Circuit Board Replacement, Circuit Board: adım 5, 1 resimden 1.
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  6. Interlink VP4550 Circuit Board Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
    • Use tweezers to gently remove it if it doesn't come out.
Sonuç
custer78
24 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Buehl Spring 2014 Ohio State, Team 1-1, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 18
Her zaman: 369
