Ana içeriğe geç
Iomega Z100S2 Case Replacement
Neye ihtiyacın var
  1. Iomega Z100S2 Case Replacement, Case: adım 1, 2 resimden 1. Iomega Z100S2 Case Replacement, Case: adım 1, 2 resimden 2.
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Case Replacement: adım 2, 1 resimden 1.
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Case Replacement: adım 3, 1 resimden 1.
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Case Replacement: adım 4, 2 resimden 1. Iomega Z100S2 Case Replacement: adım 4, 2 resimden 2.
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Case Replacement: adım 5, 2 resimden 1. Iomega Z100S2 Case Replacement: adım 5, 2 resimden 2.
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Chris Rudolph
82 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G53
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 4,271
