Ana içeriğe geç
Irulu walknbook Windows 10 tablet battery Replacement
Neye ihtiyacın var
  1. Irulu walknbook Windows 10 tablet  battery Replacement, battery: adım 1, 1 resimden 1.
    • this is what you should end up like with the tab
  2. Irulu walknbook Windows 10 tablet  battery Replacement: adım 2, 1 resimden 1.
    • first remove the orange (or other colour) bezels from the side of the tab. the all have a small hole grip.
  3. Irulu walknbook Windows 10 tablet  battery Replacement: adım 3, 1 resimden 1.
    • on the back cover there is a glass cover that covers up the screws. be carefull when removing it because it might break. use small like credit cards to seperate it but still be very carefull.
  4. Irulu walknbook Windows 10 tablet  battery Replacement: adım 4, 1 resimden 1.
    • so the back cover seperates in to two parts. after removing the glass part the screws are visible. remove all of them. the back cover can pe removed very easily.
  5. Irulu walknbook Windows 10 tablet  battery Replacement: adım 5, 1 resimden 1.
    • you then end up with all the rest of the internal parts visible. now you can replace the battery or the display. there is also a 3g port slot but i haven't tried it out yet. let me know if this worked for you.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Dili
242 İtibar
1 Kılavuz yazıldı
11Kılavuz Yorumları
Hey I have another question is it possible to replace the ram in it or no
jackroc21 - Yanıt
No that is not possible because the ram is soldered on the main board.
Dili -
where can I buy a replacement battery for this walknbook????
hushpuppy43 - Yanıt
Donde puedo comprar la batería ,no la encuentro.
will5551970 - Yanıt
Necesito comprar la batería para la irulu
Battery:7800 mAh irulu w1002
Donde la venden.
will5551970 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 6,133
