Ana içeriğe geç
Ivation IVWPDC20Y Buttons Replacement
Neye ihtiyacın var
  1. Ivation IVWPDC20Y Buttons Replacement, Buttons: adım 1, 1 resimden 1.
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Buttons Replacement: adım 2, 1 resimden 1.
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Buttons Replacement: adım 4, 1 resimden 1.
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Buttons Replacement: adım 5, 1 resimden 1.
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Buttons Replacement: adım 6, 1 resimden 1.
  7. Ivation IVWPDC20Y Buttons Replacement: adım 7, 1 resimden 1.
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  8. Ivation IVWPDC20Y Buttons Replacement: adım 8, 1 resimden 1.
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Buttons Replacement: adım 9, 1 resimden 1.
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
  10. Ivation IVWPDC20Y Buttons Replacement: adım 10, 1 resimden 1.
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Buttons Replacement: adım 11, 1 resimden 1.
    • Use the metal prying tool to lift off the cover of the buttons
  12. Ivation IVWPDC20Y Buttons Replacement: adım 12, 1 resimden 1.
    • Use the PH00 bit to remove the four screws on the metal plate around the buttons
  13. Ivation IVWPDC20Y Buttons Replacement: adım 13, 1 resimden 1.
    • Finally, use the plastic spudger to push buttons out, and then replace them
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 381
