Ana içeriğe geç
Ivation IVWPDC20Y Flash Bulb Replacement
Neye ihtiyacın var
  1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: adım 1, 1 resimden 1.
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
    FixBot'a Sor
    Yorum Ekle
  2. Ivation IVWPDC20Y Flash Bulb Replacement: adım 2, 1 resimden 1.
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
    FixBot'a Sor
    Yorum Ekle
  3. Ivation IVWPDC20Y Flash Bulb Replacement: adım 3, 1 resimden 1.
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
    FixBot'a Sor
    Yorum Ekle
  4. Ivation IVWPDC20Y Flash Bulb Replacement: adım 4, 1 resimden 1.
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
    FixBot'a Sor
    Yorum Ekle
  5. Ivation IVWPDC20Y Flash Bulb Replacement: adım 5, 1 resimden 1.
    • Pry off back outer casing using the black spudger or the blue prying tools
    FixBot'a Sor
    Yorum Ekle
  6. Ivation IVWPDC20Y Flash Bulb Replacement: adım 6, 1 resimden 1.
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
    FixBot'a Sor
    Yorum Ekle
  7. Ivation IVWPDC20Y Flash Bulb Replacement: adım 7, 1 resimden 1.
    • Gently push out the pins holding the orange tape down using the pointy end of the spudger
    • Screen and orange tape should slip out as a whole
    FixBot'a Sor
    Yorum Ekle
  8. Ivation IVWPDC20Y Flash Bulb Replacement: adım 8, 1 resimden 1.
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
    FixBot'a Sor
    Yorum Ekle
  9. Ivation IVWPDC20Y Flash Bulb Replacement: adım 9, 1 resimden 1.
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
    FixBot'a Sor
    Yorum Ekle
  10. Ivation IVWPDC20Y Flash Bulb Replacement: adım 10, 1 resimden 1.
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
    FixBot'a Sor
    Yorum Ekle
  11. Ivation IVWPDC20Y Flash Bulb Replacement: adım 11, 1 resimden 1.
    • Remove the soldering on the three wires holding the flash bulb
    • The wires are different colors: red, white, and black
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wendy Jones
225 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 511
