Ana içeriğe geç
JBL Charge 2 Battery Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Battery Replacement: adım 2, 2 resimden 1. JBL Charge 2 Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Battery Replacement: adım 3, 2 resimden 1. JBL Charge 2 Battery Replacement: adım 3, 2 resimden 2.
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Battery Replacement: adım 4, 2 resimden 1. JBL Charge 2 Battery Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Battery Replacement: adım 6, 3 resimden 1. JBL Charge 2 Battery Replacement: adım 6, 3 resimden 2. JBL Charge 2 Battery Replacement: adım 6, 3 resimden 3.
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mauzor Ilonzo
495 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G4
4 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Thanks for the manual! Easy repair this way.
Jeroen Cox - Yanıt
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - Yanıt
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 69
Son 30 gün: 287
Her zaman: 20,170
