Ana içeriğe geç
JBL Charge 2 Motherboard Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Motherboard Replacement: adım 2, 2 resimden 1. JBL Charge 2 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Motherboard Replacement: adım 3, 2 resimden 1. JBL Charge 2 Motherboard Replacement: adım 3, 2 resimden 2.
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Motherboard Replacement: adım 4, 2 resimden 1. JBL Charge 2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Motherboard Replacement: adım 6, 3 resimden 1. JBL Charge 2 Motherboard Replacement: adım 6, 3 resimden 2. JBL Charge 2 Motherboard Replacement: adım 6, 3 resimden 3.
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Motherboard Replacement, Speakers: adım 7, 1 resimden 1.
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Motherboard Replacement: adım 9, 1 resimden 1.
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
  10. JBL Charge 2 Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Use a spudger to disconnect the gold antenna connector from the main circuit board.
  11. JBL Charge 2 Motherboard Replacement: adım 11, 1 resimden 1.
    • Disconnect the microphone connector using the plastic opening tool.
  12. JBL Charge 2 Motherboard Replacement: adım 12, 1 resimden 1.
    • Use a plastic opening tool to disconnect the 3.5 mm headphone connector.
  13. JBL Charge 2 Motherboard Replacement: adım 13, 1 resimden 1.
    • Disconnect micro-b connector with a plastic opening tool.
  14. JBL Charge 2 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the connector to the USB connector using a plastic opening tool.
  15. JBL Charge 2 Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the speaker wires from the control panel by prying off with a plastic opening tool.
  16. JBL Charge 2 Motherboard Replacement: adım 16, 1 resimden 1.
    • Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
  17. JBL Charge 2 Motherboard Replacement: adım 17, 3 resimden 1. JBL Charge 2 Motherboard Replacement: adım 17, 3 resimden 2. JBL Charge 2 Motherboard Replacement: adım 17, 3 resimden 3.
    • Caution: Touching the capacitors will short out the circuit board. Push on the end of the circuit board and carefully keep thumbs on foam insulation on ends of board.
    • Remove the motherboard from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Mauzor Ilonzo
495 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G4
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Guten Tag
Vielen Dank für die prima Anleitung!
Ich habe den Fehler bei meinem Charge 2+ gefunden. Das Bauteil mit der 100 drauf ist außen mehrfach gerissen. Was ist das für ein Bauteil und kann ich das bestellen?
Liebe Grüße
Stefan
Stefan Erb - Yanıt
Hello i have a problem with component 100 but i don't now what is ? someone can help me thanks and from were can i order ?
naskicha_94 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 60
Her zaman: 8,334
