Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the screen cover from the speaker using a metal spudger.
Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
Remove the end cap of the device. Repeat the same process to remove the other end cap.
To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
Twist off the end cap and remove them from the device.
Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
Pry away the plastic battery cover with a plastic spudger.
Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
Slide the battery free.
Remove the opposite screen cover using a metal spudger
Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
Pull out the speakers from the device.
Disconnect the wiring from the speaker by using the fine tip pry tool.
Remove the speakers from the device.
Use a spudger to disconnect the gold antenna connector from the main circuit board.
Disconnect the microphone connector using the plastic opening tool.
Use a plastic opening tool to disconnect the 3.5 mm headphone connector.
Disconnect micro-b connector with a plastic opening tool.
Remove the connector to the USB connector using a plastic opening tool.
Remove the speaker wires from the control panel by prying off with a plastic opening tool.
Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Guten Tag
Vielen Dank für die prima Anleitung!
Ich habe den Fehler bei meinem Charge 2+ gefunden. Das Bauteil mit der 100 drauf ist außen mehrfach gerissen. Was ist das für ein Bauteil und kann ich das bestellen?
Liebe Grüße
Stefan
Hello i have a problem with component 100 but i don't now what is ? someone can help me thanks and from were can i order ?
