Ana içeriğe geç
JBL Charge 2 Plus Battery Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: adım 1, 2 resimden 1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: adım 1, 2 resimden 2.
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Charge 2 Plus Battery Replacement: adım 2, 3 resimden 1. JBL Charge 2 Plus Battery Replacement: adım 2, 3 resimden 2. JBL Charge 2 Plus Battery Replacement: adım 2, 3 resimden 3.
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Charge 2 Plus Battery Replacement: adım 3, 2 resimden 1. JBL Charge 2 Plus Battery Replacement: adım 3, 2 resimden 2.
    • Remove the four screws that hold the passive radiator in place
    FixBot'a Sor
    Yorum Ekle
  4. JBL Charge 2 Plus Battery Replacement: adım 4, 1 resimden 1.
    • Pop the Passive Radiator off.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Charge 2 Plus Battery Replacement: adım 5, 3 resimden 1. JBL Charge 2 Plus Battery Replacement: adım 5, 3 resimden 2. JBL Charge 2 Plus Battery Replacement: adım 5, 3 resimden 3.
    • Repeat Step 2, 3 and 4 for the other passive radiator.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Charge 2 Plus Battery Replacement, Battery: adım 6, 2 resimden 1. JBL Charge 2 Plus Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Charge 2 Plus Battery Replacement: adım 7, 1 resimden 1.
    • Remove the 6 screws that hold the white cover in place.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Charge 2 Plus Battery Replacement: adım 8, 2 resimden 1. JBL Charge 2 Plus Battery Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
80 farklı kişi bu kılavuzu tamamladı.
John Reynolds
3.354 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G1
4 Üyeler
14 adet Kılavuz yazıldı
39Kılavuz Yorumları
Great guide but where to source a battery for a JBL charge 2.
Mine failed, complained to Harman and they sent a new one and didn't want the old one so have a spare I'd like to get working.
Thanks in advance
Rob grist - Yanıt Paylaş
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
Jeanette dagastine - Yanıt Paylaş
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Tibetan Stoner - Yanıt Paylaş
Try disconnecting the battery and plugging it in again.
MarelyOscar - Yanıt Paylaş
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
Javier G. Valdivia - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 221
Her zaman: 141,326
