Ana içeriğe geç
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: adım 1, 1 resimden 1.
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 2, 2 resimden 1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 2, 2 resimden 2.
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 3, 1 resimden 1.
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 4, 2 resimden 1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 4, 2 resimden 2.
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 5, 1 resimden 1.
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 6, 2 resimden 1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: adım 6, 2 resimden 2.
    • Slide the ribbon gently out of the connector.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
John Reynolds
3.134 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G1
4 Üyeler
12 adet Kılavuz yazıldı
15 Yorum
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Yanıt
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Yanıt
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Yanıt
need the micro-usb aswell
hellgrenmicke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 51
Her zaman: 26,758
