Ana içeriğe geç
JBL Charge 2 Plus Passive Radiators Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: adım 1, 2 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: adım 1, 2 resimden 2.
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 2. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 3.
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Passive Radiators Replacement: adım 3, 2 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 3, 2 resimden 2.
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Passive Radiators Replacement: adım 4, 1 resimden 1.
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 2. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 3.
    • Repeat Step 2, 3 and 4 for the other passive radiator.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
John Reynolds
3.246 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G1
4 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 50
Her zaman: 17,903
