Ana içeriğe geç
JBL Charge 3 Battery Replacement
Neye ihtiyacın var
  1. JBL Charge 3 Battery Replacement, Front Cover: adım 1, 3 resimden 1. JBL Charge 3 Battery Replacement, Front Cover: adım 1, 3 resimden 2. JBL Charge 3 Battery Replacement, Front Cover: adım 1, 3 resimden 3.
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Charge 3 Battery Replacement: adım 2, 1 resimden 1.
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Charge 3 Battery Replacement, Passive Radiators: adım 3, 3 resimden 1. JBL Charge 3 Battery Replacement, Passive Radiators: adım 3, 3 resimden 2. JBL Charge 3 Battery Replacement, Passive Radiators: adım 3, 3 resimden 3.
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Charge 3 Battery Replacement: adım 4, 2 resimden 1. JBL Charge 3 Battery Replacement: adım 4, 2 resimden 2.
    • Insert the plastic opening tools underneath both tabs.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Charge 3 Battery Replacement: adım 5, 1 resimden 1.
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Charge 3 Battery Replacement: adım 6, 2 resimden 1. JBL Charge 3 Battery Replacement: adım 6, 2 resimden 2.
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Charge 3 Battery Replacement, Battery: adım 7, 3 resimden 1. JBL Charge 3 Battery Replacement, Battery: adım 7, 3 resimden 2. JBL Charge 3 Battery Replacement, Battery: adım 7, 3 resimden 3.
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Charge 3 Battery Replacement: adım 8, 3 resimden 1. JBL Charge 3 Battery Replacement: adım 8, 3 resimden 2. JBL Charge 3 Battery Replacement: adım 8, 3 resimden 3.
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Charge 3 Battery Replacement: adım 9, 2 resimden 1. JBL Charge 3 Battery Replacement: adım 9, 2 resimden 2.
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Charge 3 Battery Replacement: adım 10, 1 resimden 1.
    • Pull the battery and battery cable out from their housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
154 farklı kişi bu kılavuzu tamamladı.
Jack Ng
2.446 İtibar
4 adet Kılavuz yazıldı
35Kılavuz Yorumları
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - Yanıt Paylaş
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - Yanıt Paylaş
thank you so much :D
punkzmarc - Yanıt Paylaş
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - Yanıt Paylaş
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 36
Son 7 gün: 330
Son 30 gün: 1,665
Her zaman: 271,543
