Ana içeriğe geç
JBL Charge 3 Button Replacement
Neye ihtiyacın var
    1. JBL Charge 3 Button Replacement, Front Cover: adım 1, 3 resimden 1. JBL Charge 3 Button Replacement, Front Cover: adım 1, 3 resimden 2. JBL Charge 3 Button Replacement, Front Cover: adım 1, 3 resimden 3.
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Charge 3 Button Replacement: adım 2, 1 resimden 1.
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      FixBot'a Sor
      Yorum Ekle
    1. JBL Charge 3 Button Replacement, Button: adım 3, 2 resimden 1. JBL Charge 3 Button Replacement, Button: adım 3, 2 resimden 2.
      • Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
      • Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Charge 3 Button Replacement: adım 4, 2 resimden 1. JBL Charge 3 Button Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Flip open the top flap on the ZIF connector.
      • Gently pull out the ZIF connector cable with tweezers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Sunmin Yoon
2.096 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S13G1
3 Üyeler
30 adet Kılavuz yazıldı
4Kılavuz Yorumları
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - Yanıt Paylaş
Where do i buy new buttons?
Thomas Bjerregaard - Yanıt Paylaş
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - Yanıt Paylaş
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 162
Her zaman: 28,683
