Ana içeriğe geç
JBL Charge 3 Passive Radiators Replacement
Neye ihtiyacın var
  1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: adım 1, 3 resimden 1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: adım 1, 3 resimden 2. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: adım 1, 3 resimden 3.
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  2. JBL Charge 3 Passive Radiators Replacement: adım 2, 2 resimden 1. JBL Charge 3 Passive Radiators Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tools underneath both tabs.
  3. JBL Charge 3 Passive Radiators Replacement: adım 3, 1 resimden 1.
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
  4. JBL Charge 3 Passive Radiators Replacement: adım 4, 2 resimden 1. JBL Charge 3 Passive Radiators Replacement: adım 4, 2 resimden 2.
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jack Ng
2.168 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 üyesi
CPSU-ZIMMERMAN-S20S1G6
4 Üyeler
27 adet Kılavuz yazıldı
4 Yorum
i have a different model of the charge 3 it doesnt have screws but its hard to take out
Water Bass Tester (Water BT) - Yanıt
mine has screws and was also hard to pull with one hand
Carbon cookie -
Ich finde den Passivenstrahler nicht als Ersatzteil im Internet. Kann wer da helfen?
Sebastix01 _ - Yanıt
I have two of the same without screws, the process is precisely the same. Just need to do it a little bit harder
Francisco Sarmento - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 40
Son 30 gün: 144
Her zaman: 14,440
