Ana içeriğe geç
JBL Charge 3 Port Bay Replacement
  1. JBL Charge 3 Port Bay Replacement, Front Cover: adım 1, 3 resimden 1. JBL Charge 3 Port Bay Replacement, Front Cover: adım 1, 3 resimden 2. JBL Charge 3 Port Bay Replacement, Front Cover: adım 1, 3 resimden 3.
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Port Bay Replacement: adım 2, 1 resimden 1.
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Port Bay Replacement, Port Bay: adım 3, 3 resimden 1. JBL Charge 3 Port Bay Replacement, Port Bay: adım 3, 3 resimden 2. JBL Charge 3 Port Bay Replacement, Port Bay: adım 3, 3 resimden 3.
    • Take out the four 8mm Phillips #1 screws out of the port bay cover.
    • Wedge your plastic opening tool around the port bay to remove it.
  4. JBL Charge 3 Port Bay Replacement: adım 4, 3 resimden 1. JBL Charge 3 Port Bay Replacement: adım 4, 3 resimden 2. JBL Charge 3 Port Bay Replacement: adım 4, 3 resimden 3.
    • Disconnect the two bundled cable connector from the port bay.
  5. JBL Charge 3 Port Bay Replacement: adım 5, 3 resimden 1. JBL Charge 3 Port Bay Replacement: adım 5, 3 resimden 2. JBL Charge 3 Port Bay Replacement: adım 5, 3 resimden 3.
    • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
    • Pull the port bay cover off of the circuit board.
  6. JBL Charge 3 Port Bay Replacement: adım 6, 2 resimden 1. JBL Charge 3 Port Bay Replacement: adım 6, 2 resimden 2.
    • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Jack Ng
1.812 İtibar
4 adet Kılavuz yazıldı
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 üyesi
CPSU-ZIMMERMAN-S20S1G6
4 Üyeler
27 adet Kılavuz yazıldı
15 Comments
Is there a place to buy an entire replacement port bay?
indecisive_decision - Yanıt
Found the whole assembly on line for 30 bucks. Or a usb port for five from jbl
bonnie.1964 - Yanıt
Can u share a link? Need a new port bay!
Max de Groot -
Hello! My jbl charge 3 has a problem in bluetooth, I can't detect the bluetooth in any gadget. Is there anybody have an idea how to fix this?
ebataluna - Yanıt
anyone have the charging ways of this board i have 2 pads missing and would like to run the lines
Juju B - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 52
Son 7 gün: 309
Son 30 gün: 1,274
Her zaman: 47,373
