Ana içeriğe geç
JBL Charge 4 Battery Replacement
Neye ihtiyacın var
  1. JBL Charge 4 Battery Replacement, Speaker Grill: adım 1, 1 resimden 1.
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Charge 4 Battery Replacement: adım 2, 2 resimden 1. JBL Charge 4 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Charge 4 Battery Replacement: adım 3, 1 resimden 1.
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Charge 4 Battery Replacement, Passive Bass Radiators: adım 4, 2 resimden 1. JBL Charge 4 Battery Replacement, Passive Bass Radiators: adım 4, 2 resimden 2.
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Charge 4 Battery Replacement: adım 5, 2 resimden 1. JBL Charge 4 Battery Replacement: adım 5, 2 resimden 2.
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Charge 4 Battery Replacement, Battery: adım 6, 2 resimden 1. JBL Charge 4 Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Charge 4 Battery Replacement: adım 7, 1 resimden 1.
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Charge 4 Battery Replacement: adım 8, 3 resimden 1. JBL Charge 4 Battery Replacement: adım 8, 3 resimden 2. JBL Charge 4 Battery Replacement: adım 8, 3 resimden 3.
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Charge 4 Battery Replacement: adım 9, 1 resimden 1.
    • Lift up the battery cover.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Charge 4 Battery Replacement: adım 10, 3 resimden 1. JBL Charge 4 Battery Replacement: adım 10, 3 resimden 2. JBL Charge 4 Battery Replacement: adım 10, 3 resimden 3.
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
    FixBot'a Sor
    Yorum Ekle
  11. JBL Charge 4 Battery Replacement: adım 11, 2 resimden 1. JBL Charge 4 Battery Replacement: adım 11, 2 resimden 2.
    • Remove the battery from the battery socket by gently pulling on it.
    FixBot'a Sor
    Yorum Ekle
  12. JBL Charge 4 Battery Replacement: adım 12, 3 resimden 1. JBL Charge 4 Battery Replacement: adım 12, 3 resimden 2. JBL Charge 4 Battery Replacement: adım 12, 3 resimden 3.
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Sydney Seto
978 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S1G1
4 Üyeler
29 adet Kılavuz yazıldı
18Kılavuz Yorumları
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - Yanıt Paylaş
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders - Yanıt Paylaş
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 - Yanıt Paylaş
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - Yanıt Paylaş
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 159
Son 30 gün: 977
Her zaman: 86,087
