Giriş
The buttons are needed to power your speaker on and off as well as complete other functions including putting the speaker into Bluetooth pairing mode. If the buttons are not working properly they may be broken or worn down and need replacement. This guide will show you how to replace the buttons in your JBL Charge 4.
Neye ihtiyacın var
Flip your speaker over and insert the plastic opening tool into the slit on the grille.
Pry away from yourself towards the back of the speaker to release the clip.
Repeat this process for the clip on the other side.
Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
Repeat this process on the other clips around the radiator to release it from the frame.
Lift up the tape covering the button control board ZIF connector on the left side of the motherboard.
Flip up the black locking flap on the ZIF connector with the tip of the spudger or your fingernail to release the white ribbon cable.
14 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi - where can I buy the button control board?
How do I boot up JBL CHARGE 4
