Ana içeriğe geç
JBL Charge 5 Fabric Case Replacement
Neye ihtiyacın var
  1. JBL Charge 5 Fabric Case Replacement, Fabric Case: adım 1, 3 resimden 1. JBL Charge 5 Fabric Case Replacement, Fabric Case: adım 1, 3 resimden 2. JBL Charge 5 Fabric Case Replacement, Fabric Case: adım 1, 3 resimden 3.
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Fabric Case Replacement: adım 2, 3 resimden 1. JBL Charge 5 Fabric Case Replacement: adım 2, 3 resimden 2. JBL Charge 5 Fabric Case Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Fabric Case Replacement: adım 3, 3 resimden 1. JBL Charge 5 Fabric Case Replacement: adım 3, 3 resimden 2. JBL Charge 5 Fabric Case Replacement: adım 3, 3 resimden 3.
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
Sonuç
Kat Whaley
753 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 68
Her zaman: 353
