Ana içeriğe geç
JBL Charge Battery Replacement
Neye ihtiyacın var
    1. JBL Charge Battery Replacement, Case: adım 1, 3 resimden 1. JBL Charge Battery Replacement, Case: adım 1, 3 resimden 2. JBL Charge Battery Replacement, Case: adım 1, 3 resimden 3.
      • Make sure the device is powered off before you begin to disassemble the speaker.
      • Remove the trim from the speaker using a jimmy or metal spudger.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Charge Battery Replacement: adım 2, 2 resimden 1. JBL Charge Battery Replacement: adım 2, 2 resimden 2.
      • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
      • Remove the battery cover and set the cover aside.
      FixBot'a Sor
      Yorum Ekle
    3. JBL Charge Battery Replacement: adım 3, 2 resimden 1. JBL Charge Battery Replacement: adım 3, 2 resimden 2.
      • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
      • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
      FixBot'a Sor
      Yorum Ekle
    4. JBL Charge Battery Replacement: adım 4, 2 resimden 1. JBL Charge Battery Replacement: adım 4, 2 resimden 2.
      • Use a spudger to lift the battery out of the device.
      • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
      • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
      FixBot'a Sor
      Yorum Ekle
    5. JBL Charge Battery Replacement: adım 5, 2 resimden 1. JBL Charge Battery Replacement: adım 5, 2 resimden 2.
      • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. JBL Charge Battery Replacement: adım 6, 2 resimden 1. JBL Charge Battery Replacement: adım 6, 2 resimden 2.
      • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
      • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
      FixBot'a Sor
      Yorum Ekle
    7. JBL Charge Battery Replacement: adım 7, 2 resimden 1. JBL Charge Battery Replacement: adım 7, 2 resimden 2.
      • Once the back casing is open, disconnect the three white connectors from the motherboard.
      • Remove the upper casing.
      FixBot'a Sor
      Yorum Ekle
    1. JBL Charge Battery Replacement, Battery: adım 8, 1 resimden 1.
      • Turn your attention to the back casing removed in Step 7.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Charge Battery Replacement: adım 9, 1 resimden 1.
      • Using a razor blade, remove the glue holding the battery cable in place.
      • Use multiple vertical cuts to remove pieces of the glue.
      • Be careful not to cut the battery cables.
      FixBot'a Sor
      Yorum Ekle
    3. JBL Charge Battery Replacement: adım 10, 1 resimden 1.
      • Remove the foam surrounding the battery cable.
      FixBot'a Sor
      Yorum Ekle
    4. JBL Charge Battery Replacement: adım 11, 1 resimden 1.
      • To remove the battery, pull the battery cable through the hole.
      • This entire white piece needs to be replaced (if replacing the aux/usb port).
      FixBot'a Sor
      Yorum Ekle
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Joe Durand
2.313 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-4, Lancaster Spring 2015 Cal Poly, Team 12-4, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G4
2 Üyeler
24 adet Kılavuz yazıldı
35Kılavuz Yorumları
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - Yanıt Paylaş
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - Yanıt Paylaş
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose - Yanıt Paylaş
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - Yanıt Paylaş
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 86
Son 30 gün: 414
Her zaman: 239,409
