Giriş
If your speaker is not working or sounds like it's not delivering the high quality you expect from JBL, maybe you need to replace the battery. Replacing the battery can breathe new life into your worn device.
Neye ihtiyacın var
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
This is NOT liquid Electrical tape! I recommend using 3M adhesive silicone. If you are doing this repair then you can find the 3m adhesive silicone at automotive stores. Liquid tape hardens and 3M adhesive remains mailable vs the rock hardening effect of liquid tape.
Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
The two screws on the right side (side with the USB port) are too long to extract with the iFixit screwdriver in the basic kit. I needed to use a regular thin PH2 screwdriver to get them out.
I had this problem also, whenever putting the screws back in there were still air pockets in the side with smaller screws
Once the back casing is open, disconnect the three white connectors from the motherboard.
Remove the upper casing.
Hi , Thanks a lot in my speacker i had broken plastic part which affect clear sound with your guide i open mine seasily and take it out now i have beand new sound which i had before. thanks again.
Turn your attention to the back casing removed in Step 7.
where can i get the usb port with the cable that goes to mother board and it has the thre colors red black white please give me any place where i can buy it
Using a razor blade, remove the glue holding the battery cable in place.
Use multiple vertical cuts to remove pieces of the glue.
When reinstalling I used E600 glue to replace this goop of glue that is removed.
To remove the battery, pull the battery cable through the hole.
It looks like it would be difficult removing the USB assembly because mine looked very well glued in that little space meant for the module to fit.
Thanks for this guide
I replaced the battery but it still won’t cheat fe, could the usb port be damaged and where can I purchase a usb port for my gen1 JBL Charge speaker?
37 farklı kişi bu kılavuzu tamamladı.
32 Yorum
How i replaced a new battery in myjbl reflect headphone bluetooth
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose -
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
what type of battery should I be replacing the original battery with?
Hi, I am Shashikant Shinde,
I have bought JBL Flip 3 ( Black ) few months back. Surprisingly the battery is not sustaining for long time. I feel the life of the battery should have been stronger than this. Within a year itself the battery has gone bad I think. Has any one a guide to replace the battery in JBL Flip 3 speaker. It is difficult to give the speaker in the service centre, as it is closed on saturday and sunday.
Its all very well to have installation instructions but where do you buy the battery and what are the reference numbers for the jlb spaekers
sir, i bought this system just six month back. now its not getting on atall . please tell me what should i do????
sir please give me a solution .
what kind of battery dies in 7 months of purchase. IT MEANS JBL CHARGE2 IS BAD PRODUCT.
sounds like you got a lemon ive had my jbl charge shadow since it came years ago havent had a single issue
From where can i buy the battery for jbl charge 2
Hi all,
Just realized i need to change battery in my JBL Charge. First would like to say thanks for the explanations on how to get to that bloody battery ^^
I have one question:
Is it possible to upgrade that battery with one that will last longer and maybe charge quicker?
If yes what battery can i use?
Thank you in advance.
Great instructions. Slightly diff on my charge 2+ but i got the whole idea from here. My charge 2+ started with batt issues about 1 month ago i could only do 1hr playback at mid vol…. i guess since oct 2015 with high usage (upto 2hrs per day) and most wknds for 5hrs and more. it was about time. New batt working great so far. Be careful not to drain your batt till red light flashes. Recharge when ur down to 2 lights and stop when the 5th light flashes. That way u protect from overcharge.
The charge 2+ is a great device.
Does anyone know what type of battery the JBL pulse 1 actually needs? Also any further instructions on where to acquire this type of battery for a possible repair assuming that’s the actual issue with this slightly expensive/uselessspeaker (is it the battery or charge port that’s malfunctioning? Or both? If speaker turns on while plugged in connects to a device, sounds like the speaker is blown unless I turn it way down, then shuts off completely all while the battery meter indicates a full charge. I enjoy fixing m own tech, any info on the matter would be greatly appreciated!!!!
Thanks! Great guide, much easier than it seemed at first. Now my speaker is working great again!
Great manuel,works like new after resetting the battery.thx
My JBL Charge (1) is about 3 years old, so battery life is badly deteriorated and is bloated a lot. Is it possible to keep using my JBL Charge always plugged to the charger even with the battery removed?
Please where can I get JBL Bluetooth Speaker battery in Nigeria. Thanks
Great guide … thank you very much. If I was going to add anything, it would be a little warning about opening the main cover. I’ve got fairly strong hands, and I found it pretty difficult to fully separate the cover from the main body, even once I had it started at the corner shown in the guide. The adhesives used by the manufacturer around the edges of this cover are strong, and you have to be patient/careful as you apply the force required to pry all the edges of the cover up and away from the main body, e.g., so you don’t lose control of the Charge, the cover, or your tool as you’re working.
my jbl endurance peak only charges 10%
this IS not REAL!!!! omg no way
My charge for a won't take a charge won't power up however after charging it for a few hours if I plug something into the USB it will charge the device I plug in there have you ever encountered that problem
ottimo, immagini e indicazioni perfette
Please share how to replace boombox1 battery please
My JBL speaker will only work if I plug it in??? Please Help!!!
Can the usb port on the JBL 1st gen Charhe speaker be replaced and if so where can I purchase one, I replaced the battery but it still won’t charge with a bone hood cord?
