Ana içeriğe geç
JBL Clip 2 Carabineer Mount Replacement
Neye ihtiyacın var
  1. JBL Clip 2 Carabineer Mount Replacement, Carabineer Mount: adım 1, 1 resimden 1.
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Carabineer Mount Replacement: adım 2, 1 resimden 1.
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Carabineer Mount Replacement: adım 3, 1 resimden 1.
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Carabineer Mount Replacement: adım 4, 1 resimden 1.
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Carabineer Mount Replacement: adım 5, 1 resimden 1.
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Carabineer Mount Replacement: adım 6, 1 resimden 1.
    • Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Carabineer Mount Replacement: adım 7, 1 resimden 1.
    • There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Hong
1.014 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 üyesi
UWT-ROSE-W17S2G2
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
i want to find that part ,dou you have web link to by
breakdancesok - Yanıt
where can i find this piece please
Daniel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 89
Her zaman: 8,950
