Ana içeriğe geç
JBL Clip 2 Speaker Replacement
Neye ihtiyacın var
  1. JBL Clip 2 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: adım 2, 1 resimden 1.
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: adım 3, 1 resimden 1.
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: adım 4, 1 resimden 1.
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael Hong
1.014 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 üyesi
UWT-ROSE-W17S2G2
4 Üyeler
7 adet Kılavuz yazıldı
6 Yorum
If no parts are required what are you replacing the speaker with?
Tom - Yanıt
Tom is right you know!
edward felix - Yanıt
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Yanıt
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Yanıt
Hi, where I can buy the speaker please? Thank you.
Govan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 56
Her zaman: 6,485
