Ana içeriğe geç
JBL Clip 3 Carabiner Clip Replacement
Neye ihtiyacın var
  1. JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: adım 1, 2 resimden 1. JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: adım 1, 2 resimden 2.
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: adım 2, 2 resimden 1. JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Carabiner Clip Replacement: adım 3, 1 resimden 1.
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Carabiner Clip Replacement: adım 4, 2 resimden 1. JBL Clip 3 Carabiner Clip Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: adım 5, 2 resimden 1. JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: adım 5, 2 resimden 2.
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Molden
465 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 26
Son 30 gün: 100
Her zaman: 3,406
