Ana içeriğe geç
JBL Clip 3 Speaker Housing Replacement
Neye ihtiyacın var
  1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: adım 1, 2 resimden 1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: adım 1, 2 resimden 2.
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: adım 2, 2 resimden 1. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Housing Replacement: adım 3, 1 resimden 1.
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Housing Replacement: adım 4, 2 resimden 1. JBL Clip 3 Speaker Housing Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle Montague
238 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 65
Her zaman: 1,200
